Ccza engine in 2010 vrs, which fuel pump?
So looking through my log book after noticing I had a tfsi car with a tsi engine, I know the tfsi has a less efficient fuel pump, but what about the ccza engine? Will this have the higher rated fuel pump that tsi engines are ment to have?
Or is there a part number or stamp to identify which pump is which (I.e more flowing)
Yes the tsi has the higher pressure fuel pump guess u have a run out pfl 09 model same as my old car
Ccza is a tsi. And has the better fuel pump as standard
Pete mine is the mid 2010 fl model, at least it will have the better fp :)
Does this mean any mods I buy for my car have to be tsi, or do they have to be tfsi parts? As planning to go k04
Tsi intakes totally differant
Sports exhausts no differance between tfsi/tsi also estate i believe are the same
Suspension upgrades will be the same also.
KO4 just bolt on with relevant parts i.e injectors
Forget the tfsi bit yours is a Tsi model
Pete is mostly right, you will need a specific Ko4 kit for 2.0 TSI though, and you wont need injectors.
