programing clocks
whats needed to re program the dash clocks is it vag com ? as mine has police spec clocks at the min , and i want to fit the vrs ones and can the milage be adjusted ?
Out of interest why would you want to swap out the police spec ones ?
as on dial is silver and the speedo is black looks odd
fair enough
If you want to swap the whole dash pod then you will need the immobiliser codes for both pods. IIRC you can't adjust the mileage with VCDS, you need vag-tacho to do that.
Sent from my Nexus 4 using Tapatalk 2
