Help needed for decoding faultcodes
Hi all
On my skoda octavia 1.6 gasoline, the engine light is on. I went to the skoda dealer and they told me that the EGR vent and some tubes needed to be replaced. A few days after the vent and tubes was replaced, the engine light went on again and this time they told me that the fuel mixture needed to be adjusted. This time i didn't believe them, and I bought a vag-com cable to readout the fault codes myself.
First the symptoms. The engine runs irregularly at steady speed and in idle. Periodically it is more intense.
Here is the fault codes :
16554 - Fuel Trim; Bank 1: Malfunction
P0170 - 35-10 - - - Intermittent
16521 - Shareware Version. To Decode all DTCs
P0137 - 35-10 - Please Register/Activate - Intermittent
16556 - Shareware Version. To Decode all DTCs
P0172 - 35-10 - Please Register/Activate - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
16514 - Shareware Version. To Decode all DTCs
P0130 - 35-10 - Please Register/Activate - Intermittent
17911 - Shareware Version. To Decode all DTCs
P1503 - 35-10 - Please Register/Activate - Intermittent
16556 - Fuel Trim; Bank 1: System Too Rich
P0172 - 35-10 - - - Intermittent
Readiness: 0000 0001
I need some help locating the issue. From the fault codes above I think is might be the MAF sensor or a bad lambda sensor, but i'm not sure. Does anybody have a clue about what is wrong with my car?
Seeing as you are using VCDS lite look at the Ross tech wiki.
Sent from my Nexus 4 using Tapatalk 2
