Vrs oil temp high?
Just got home towing a smallish 4 birth caravan and on the way my oil temp has been around 100-105 degrees (prosport gauge) and the oil light has been constantly flashing. Oil level is correct. Any ideas people?
I think its overheard me talking to the wife about upgrading to a new model soon.
Oil pickup in sump blocked up,
I would be a little worried if oil lights flashing, what oil you using in it because i tow with mine sometimes but never had that,
What does it normally run at when on a decent run, guessing around 90 same as coolent temp???
What colour was the oil light? If its red then I think it's a pressure warning, will need to drop your sumo and clean the oil pick up pipe.
Cheers guys. Ill strip it this weekend n clean it up. Top of engine is still moist so may have caught it early. Its a red flashing light.
Red flashing is oil pressure lets hope you caught it early
Do not drive until done !!
Is it a common problem with these engines? Whats best way to sort it?
Seems to be getting really common, the problem is the oil pick up pipe strainer getting blocked over time. Mine was running fine at 130k when I changed it while getting my cambelt done, it was nearly blocked
Sent from my Galaxy S3, not a Crapple!
Mines done 165k cant complain really. Lol
Do not drive it!
Is it likely to need a pump aswel?
Not usually, just a pickup pipe
Ok mate will get the bits ordered cheers
Just hope that you've caught it in time m8,good luck
