Octavia sat nav niggle
I have a strange problem which I know someone will know the answer to. When I set the sat nav destination and start my journey route guidance 'used' to appear on the small display in between the speedo and rev counter too. It has stopped doing that now, have I done something dumb? It is whatever the standard sat nav is fitted to a '56 plate VRS Octavia. thanks in advance.
Have you tried toggling the display options with the little button / switch on the indicator stalk?
^^^ unless you've been playing with VCDS! Otherwise no reason for it to disappear...
If it is a Columbus do a reboot of it. Can't remember the button combination to do this though.
Has happened to me before and a reboot cured it.
Sent from my HTC One X using Tapatalk 2
Just noticed you said 56 plate so probably a MFD2 but the same trick might work.
Reboot Columbus = <, > & mic
