S3 lower strut brace audi part numbers
Anyone know the part numbers? I went up to audi today with a few part numbers i researced....just want to make sure im right.... all came to 48 quid in total....thoight it was prety good
8L9806529A bracket         £57.18+vat                           S3 strut brace upper and lower with fixings
8N0199403B support         £25.80+vat
N10467901 bolt-hexagonal head x2   56p
N90914701 rivetted cap nut  x2
From the useful parts no. sticky at top of section.
Aha cheers do you need the bracket i take it....
No the bracket is the upper brace, as you mention only fitting lower you just need:
yh just the lower already have the upper....nice little mod for less than 50 quid all new from audi :)
The holes to fit the lower are already there arnt they?
Yep
Yes you first fit the captive nut and then screw up bolt, this will compress the captive nut and leave tight in the hole. Unscrew the bolt and fit brace and bolt up job done.
Or if you are careful and have a helper or a spare jack or like i did balance brace on knee's :rofl: you can bolt up and compress with brace in place.
