Help fitting a OMP / Momo steering wheel
Hi Folks
Anyone got any pics of the wiring for the fitment of one of these.
steering wheel came with boss and few wires , think for airbag bypass, but no instructions....
When i fit my momo wheel i used the existing airbag loom and removed airbag connector and just put some spades on the horn connections. As for the airbag just disable with vcds takes 2 mins. Airbag light flashes 5 times on startup then goes off :-) no need for resistors mate
Ah ok cheers
Did you leave all the parts still attached when you removed the steering wheel, i.e the plastic ring etc.
This is what i did mate. aftermarket wheels usually just have male spade terminals on the horn. No need to remove slip ring bud just remove airbag(hardest bit) then either use a spline socket or can get away with a big torx bit. Wip the std wheel off, mod the loom as above then connect horn up and fit the new wheel :-)
You star buddy, just what I wanted to know.
cheers
