Retrofitted Bolero and Maxidot.
Hi all,
Ive just fitted a 2012 Bolero unit into my 2006 Vrs along with an updated gateway. Everything works fine except i have lost the 'Audio' option in the Maxidot.
I've run VCDS and the following fault comes up.
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 74634 km
Time Indication: 0
Date: 2000.00.00
Time: 16:45:10
I'm assuming this is the reason for the maxidot issues! is there a way to get the display working? Its not a biggie, but i would like the display if its possible as in every other way the Bolero is way ahead of the Stream :rock:
coding
the bolero probably voded for bap protocol, that needs to be removed
Can BAP be removed from a 2012 Delphi Bolero? From what I can find on this site it would seem not.
I've checked on VCDS under the long coding for radio and there are only 5 bytes, none of which have A BAP option within?
Has anyone managed to get the communication working between a new Delphi Bolero and Pre FL Maxidot?
the fault is nothing to do with the radio
try entering the code to the radio coding
010004000401
the Bold one is used to disable BAP on other radios, cars with BAP have a zero
010004000401
I've just tried this Eddie, and it's not worked :( . In that byte in the Radio coding, there are 4 options on active monitoring of various speakers.
Also getting the fault below, even though ive fitted a double Fakra adaptor fitted any ideas whats causing this? The radio works fine in both FM and AM!
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 110
Mileage: 74703 km
Time Indication: 0
Date: 2000.00.00
Time: 08:33:49
Edited by Mr G 76
