Juddering Xenon
I have an 06 Octavia vrs fitted with factory fitted Xenons but just recently have noticed that when you switch on the lights and they go through their down and up level setting sequence the drivers side light judders on the way up and sometimes does not appear to set correctly as it appears to be slightly higher than the passenger side.
Not so high as to blind oncoming traffic but noticeable.
Any one got any ideas or is it a case of take it to a dealer to sort, but I hope not as don't really want the expense at the moment. :sweat:
Might just need some light weight grease on the mech system inside.
How and where is the mechanism?
Is it a case of removing the headlight and the mechanism is inside the light unit?
