Ch/Lh blackline
Got a 2013 blackline,got vcds; tried turning on ch/Lh tried it with fog lights still no joy, what am I doing wrong? What are the codes?
Doesn't work my friend as the sensor is missing, there is a thread somewhere where you can can hit the light stalk.
Ok at least that puts that one to bed, cheers mush. Oh and just so you know followed your instructions to the letter yesterday and I now have a blue tooth hands free phone installed. Top tip !!!! Anymore?
You can activate the coming home so that it operates by leaving the headlight switch in the on position and flicking the high beam stalk after removing your keys.
How do you do that m8? What are the codes please?
Flick towards or away?? Many Thanks
Doesn't seem to work for me, but I think I changed it to fog lights? What does it need to be on?
Flick towards you like when you flash. The coding was Byte 17 Bit 6 Ticked - Leaving Home Light, Byte 12 Bit 2 Ticked - Coming Home light through manual in module 9 Central electrics. This may be slightly different on pre-fl
