Exhaust issues, can anyone help?
Hi all, I have bought myself a milltek system. Unfortunately it doesn't fit to the decat. I did check the net before I fitted with regards to sizes, but the internet was well off!
I was wondering what the best options are?
The first and the obvious would be to buy the sports cat to match, but I don't have those dollars atm.
The next is, can you buy just a bigger decat pipe? The downpipe is fine, just need the bigger decat.
And finally, would this do the job http://www.ebay.co.uk/itm/Universal-Exhaust-Pipe-Reducer-6-step-easy-to-use-new-/110446106661?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19b719d825
regards,
Damian.
Try long life exhausts or pipewerx depending where you are! They both fabricate on the car,so are custom fitted! Shouldn't be to expensive esp from long life and its all stainless!
Longlife have a branch in bridport too!!
About an hour an a half from where I am! I did go to the local one of these near me, they claimed I would need a whole new system! I just bought it!
BS, all you need is a 1 piece sleeve probably.
As the system may well be the same size as your decat you are fitting to, although you don't actually state why it won't fit???
So you either need a 6" sleeve that you can fit system and decat into and clamp up
something like.
http://www.ebay.co.uk/itm/2-5-3-64mm-76mm-Stainless-Clamp-on-Exhaust-Pipe-Connector-Adapter-Reducer-/251257100319?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a8017181f
or system is different diameter to the decat to which you will need a stepped reducer
something like
http://www.ebay.co.uk/itm/STAINLESS-EXHAUST-PIPE-REDUCER-adaptor-step-joint-sleeve-70mm-65mm-2-75-2-5-/230973929722?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35c71e78fa
but check diameter of both your exhaust's first.
