Air Con
Hello,
The air con on my 3 year old fabia has stopped working :mad: It made a some funny noises then basically stopped blowing cold air.
I'm guessing it needs recharging ?. How long should the system mormally stay charged ?.
Any idea how much it will cost me and can my dealer do it or do I need to go to an air con specialist ?.
I'd go for a specialist, possibly a tuner :)
Will cost 50-60 quid to get it regassed, but I'd take it to your dealer and get it on their diag rig as it may just be a case of the evaporator temp sensor packing up (mine did it 2 months out of warranty). It's a 30 quid sensor, but requires the dash to be taken out to fit it, so labour is pretty high, but you might find a friendly Briskodian can help you out :D
Chris
Dash doesnt need to come out to do the sensor, 20 minute job max.
  • 2 months later...
Hi, my car have this fault can you give me some information how to replace this sensor :confused: my workshop here in Portugal wants to remove the dash :eek: .
Thanks in advance
Oliveira99
Well today i started to try to change the evaporator sensor without removing the dash... :rolleyes:
It isn
I only know where the sensor is on RHD cars (which is between the windscreen and instrument pod). On LHD cars, it may still be on the right hand (passenger) side which may mean less of the dash needs removing :D
Let us know when you find out :D
Chris
It isn
Update...
I try using the metod of non removing console, i have small hands :D ,
But i was afraid of damage the ventilation housing when removing the sensor, i never ever change the sensor... and hope after this... never need to change again. :o
After removing every bolts i stop... i forgot that i don
