Which Steering control module?
Hi all,
I know this has been kind of covered in different posts but I am confused.
I am new to Skoda Modding and have just received my VCDS Dongle and on scanning the modules in my car, this is the info about the steering module;
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BB HW: 1K0 953 549 BB
Component: Lenksäulenmodul 036 0070
Coding: 0000002
Shop #: WSC 73430 790 00000
VCID: 73E1DBFF6B25
The Ross-Tech site gives this info about my module;
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
1K0-953-549-BB Type 2 SW 0070 Lowline Yes - - 1K0-953-549-BC Type 2 SW 0070 Midline Yes - #1 1K0-953-549-BD Type 2 SW 0070 Highline Yes 1.3 #2
  • Slip Rings
    • Type 1: 1K0-959-653 and 1K0-959-653-A
    • Type 2: 1K0-959-653-C and 1K0-959-653-D
    [*]Variants
    • Lowline: No additional Options/Features
    • Midline: Cruise Control, Board Computer
    • Highline: Cruise Control, Board Computer, Multi-Function Steering Wheel
    [*]Steering Angle Sensor
    • Yes: The Steering Angle Sensor (G85) is installed directly at the Steering Wheel/Slip Ring.
    • No: The Steering Angle Sensor (G85) is part of the Electro Mechanical Steering Assist.
    [*]Notes:
    • #1: Does NOT allow Cruise Control Retrofitting, in such a Case you need to replace the Steering Wheel Control Module.
    • #2: Manual Transmission only, does NOT support Ignition Key Lock.
So, I have the LowLine Module which will need replacing. I would like the option of a MFSW in the future so will need a HighLine module. My question is, With which module? How do I work this out? Do I just go for the 1K0-953-549-BD or is it more complicated than that? If so, What implication does the LIN Version and the note #2 have, if any?
Once I have sorted this out I then need to find a CC Stalk that is compatible, my plan for this is eBay (for both parts) unless anyone has a better parts source.
Any assistance on VCDS coding will be greatfully received also.
Thanks in advance.
