fault code mk1 vrs octy
Hi people, had a fault code p1137 fuel trim:bank 1 system too rich!?!?!? any ideas folks on what could cause this?? how long is a peice of string etc...... just wondered if there was a common fault?
cheers in advance :)
Are you experiencing any problems at all?
Clean your throttle body first and then look for leaks in all the breather hoses.
It's easy to find vacuum leaks with the engine idling, just don't burn yourself! Have a good poke around under the inlet manifold. Basically have a good look at all hoses and connections.
ok cheers guy, no no running problrms at all??
guys even lol
