Coolant light comes on when I start from cold, have opped up with correct stuff
But the light still pings on in the morning. After 5 mins driving and restarting the motor the light then goes out.
I used the correct coolant to top up, but it does not seem to have worked.
Any tips ?
You're probably the several thousandth person to have suffered from the dreaded "dirty prongs" error.
On a cold engine, open the expansion bottle, and look for two metal prongs sticking down into the coolant. Scrape these a few times with a flat blade screwdriver. This should cure your false positive warning light.
+1 wot he said ^
I get it occasionally and that has always worked. The muck is just breaking the electrical signal the sensor needs.
Edited by Aspman
