boosr gauge read out
hi all
just fitted a gauge. Wanted to know what i should be looking for on the dial. Its a standard vrs.
at idle in getting -22.
foot off and coasting -30
1st gear foot down, just under 0.
2nd gear foot down, about 3psi
3rd, 4th and 5th spikes at about 10-11 psi then settled at about 8 - 9 psi.
is all ok?
1st and 2nd gear doesn't sound right, is your traction control cutting in?
Apart from that sound right to me for a standard vrs
Idle should be about -26.
Which could indicate a vac leak.
1st and 2nd not right should be the same through thw gears.
