What is terminal 30 on a fabia vrs
As above as that's the fault code for terminal 30 relay can anyone help as having bother with the traction control coming on at 40mph and won't go any higher but if I turn the asr off the car drives fine and that's two diagnostic machines I've had it on
Edited by m4cwo
Terminal 30 is a generic name for a permanent live feed from the fusebox, ie it is permanently live even if the ignition isn't turned on.
Does the battery light come on with the ignition?
Yeah battery light comes on with ignition
Has the terminal 30 fault code been erased? And if so, has the fault code come back? And I have to ask... Have you had any work done on your tyres since just before you noticed these symptoms happening? I.e. new tyres, different wheels etc.
  • 9 years later...
Do you find the issue?
