BT Audio Speaker Settings?
Hi again people.....
Wonder if any of you can help me out with this as my car didn't come with a manual and I'm still waiting for the dealer to post me one......
Anyway, I've got a 60 plate vRS with the Bolero system in it and all set up for BT Audio, however whenever I play anything out of it it only comes out the right side speakers. I've tried all the settings including balance & fader etc and all are set up ok anyone know how to sort this?!?
Thanks on advance
Hi, did you get this sorted? I have a similar problem where my A2DP music only comes through in mono, although it is coming through all speakers. My dealer is at a loss so not sure what to do now.
I don't know the full answer but I have seen reference to this problem on the internet in other searches. Have either of you recently updated your bt module? As what I have seen relates to needing extra wiring between head unit and bt module to take advantage of stereo streaming that the newer modules support, but older ones didn't.
I just found this for example:
http://vwnavi.com/volkswagen-factory-fit-navigation-systems/rns-510-mfd3-navi-system/bluetooth-telephony/14105-9w7-2010-tiguan-a2dp-streaming-audio-right-side-only.html
Hope that helps
Adam
Thanks Adam, I think in my case it's a software issue with the head unit, but getting my dealer to properly look in to the problem is proving.....difficult!
