Octavia Vrs Headlight/sidelight not working
As title, my Octavia vrs passenger headlight and sidelight are not working, I've changed both bulbs and still no luck, any ideas? Fuses also seem to be fine :/
Let me guess; the headlight doesn't work on either dip or full beam? The foglight may not work either?
I'm fairly sure you've got an earthing failure.
Hi, I've just had a look, and you're right, there is nothing working on the passenger headlight. If it is an earthing failure, how do I fix this? Also, could it be a relay fault?
I've just had a look at the relays above the pedal box, and when the headlights are in their on position with the keys in 2nd ignition, there are no clicking sounds or anything coming from the relays. So most likely earthing failure?? Any help is appreciated !!!
