Removing blank switches above headunit
hi, any idea how to remove these switches? the rear window heater is the only 1 in use in my fabia. just a screwdriver or something?
i used my keys! but yeah they pop out with some pressure :)
just cut up an old tesco clubcard! worked a treat for unclipping them
can you use an old homebase card ? :confused:
mmm not to sure, with Hombase being owned buy Sainsburys who arnt doing very well compared to Tesco it might be a bit cheap and break!! :D
My Octy one just prised out with a small flathead screwdriver.
Word of warning to Octy RS drivers.
If you want to replace the blank next to the fuel flap button with the heated seats button which is there on a 4x4 or L&K be warned that they cost
The heated seats button isn't just a button, that's why it's so expensive ;)
I think it weights more than my headunit! :rofl:
If you've got radio keys you'll find it easier if you take the radio out first. Curiously there are varying notches on the blanks and switches meaning that if you want to rearrange them, you have to trim bits off...
did it today, easy as. screwdriver n they came out easily. i took them all out except the one thats in use and had them all lined up in the order they were in, but thought that it didnt actually matter what ones go where until the last post by DRJ! iv mixed them up 2! shoulf be able to figurre out what ones go where tho
Sainsburys hasnt owned Homebase for years :P
i did that but some hpow every combanation i have done they still arnt sitting straight it is anoying.... apart from the heated window, heated seats, asr, wat are the other 2 blanks for? :confused:
Why would you wanna remove them?
