Another Superskoda (Milotec?) Bonnet Strut thread with pictures
I do like that mate,good work :)
Nice, you did like I  did, that is painted the bonnet adapter the same colour of car
Looks good. Couple of questions though.
Does it feel strong enough to properly support the bonnet.
Where is this listed on Superskoda?
Ta
Chris
Ta
Chris
It is strong enough, the only drawback I find is that the bonnet when lifted is lower than original, have to wear helmet :rofl:
Edited by alberg
Does the long bracket sort of "stick out" like a sore thumb?
Not when it's sprayed up to be colour coded
could you measure the dimensions of the shock, Possibly a slightly longer one could be fitted to rise the bonnet another bit?
Just bend over a bit further :)
That would all depend on who was standing behind me  :rofl:
It certainly wouldn't be me :)
youl need to make sure it will fit between the two mount points when the bonnet is in the closed position. if its longer, you may need to adjust the mounting point on the bonnet
Good point, well made :rock:
And thinking about it that won't be possible, as the next point along the wing is the rubber bonnet support, and it wouldn't pay to do anything with that
