Which firmware to my Columbus?
I have a Skoda Superb 2011 with a Columbus unit.
I don't have a hidden menu on my Columbus so how do I know what firmware i need to update it with?
Its easy enough to slide it out and have a look at the sticker on the top. The trim surrounding it comes off easily enough with a credit card or similar. There are then 4 screws to remove and it slides out. Don`t unplug anything especially the airbag light or it will need to be reset with VCDS
Thanks!
I have this unit: 3T0 035 680 A (3T0035680A) H42 with SW 2724 in my Skoda Superb.
Can i update to 4020?
Exactly the same as mine. I updated to 3810 without any problems but when I tried 4020 it didn`t work for me, it failed twice at 42%, but I do intend trying again soon. 4020 has worked for a lot of people without any issues. There are several recent threads about it
I can only find one link that works and it is a modified 3810 firmware.
Do you have it?
Edit:
Is it 3810a_noru.rar?
Can i burn it to a DVDR or must it be a CDR?
Edited by Rubby
To be honest I can`t remember which version of 3810 I used but I`m sure I got it from My-GTI
I did try the 3810a_noru.rar and it worked perfect!
Thanks!
I tried the 4020 today and it didn't work.
I had to go back to 3810.
Just out of interest did it fail at 42%?
I didn't wacht the install so I dont know,
Sorry can`t help you with that. As far as I can tell I can`t get a hidden menu, unless its a feature of 3810, I wasn`t aware of that. I`ll try it later. How did you get the hidden menu to appear.
Hmm... The sticker on the Columbus unit says 3T0035680A but the hidden menu says 3T0035680B?!?!?!
http://www.flickr.com/photos/53593792@N04/9525550322/
That would suggest that it has already been upgraded from a lower firmware to the current one.
Mine also shows that it is 3T0...B on the menu but 3T0...A on the sticker.
There is no reason why you can't upgrade to 4020 other than a duff download or unzip or burn or media your Columbus doesn't like (they are very fussy).
Upgrading to 3810 or 4020 will automatically enable the hidden menu (and VIM).
With earlier firmware it can be enabled with VCDS.
Hold the 'Setup' button for about 30 seconds. If you get past the 'Radio' submenu then you've arrived at the hidden menu.
How did you know it had failed?
Was there an error message? Or an ejected disk?
Knowing this may help trouble shoot your problems.
Ejected disk and swl error or swl failure I don't remember.
That's probably the Columbus not liking the CD or not being able to read the CD.
I used TDK cdr disks for both firmwares. Burned at 8x. 3810 worked perfect but not 4020.
"There is a saying" that Columbus likes DVDs better than CDs for some technical reason.
Still I burned 5238 on Verbatim CD-R with Windows XP standard app (no speed adjustment) on 10-year old Pentium-4 PC. It standartly took about 1 hour to install, with ocational pauses, quite long and frightening.
