wing badge removable?
Can I remove the comfort badge or has it gt pins behind.?
I doubt it'll have pins as it means a different wing for each model (EG the vRS doesn't have side badges). Personally I'd take it off. If it does have a hole then just get some double sided tape/pads and refit the badge :)
there is no hole,just heat it up with a hairdryer and shimmy a bit of fishing wire behind it.
You will be left with some sticky residue which goes away with some wd-40 and a cloth
Ok thanks for your help guys.
