oil type fabia scout
anyone know what engine oil to use for fabia scout 1.4tdi pd 80? manual only gives part number not type.sorry if already answered new to forum. thanks.
It needs to meet the VW spec of 505.01 or 507.00 if the car has dpf. Though you can use 507.00 even if it doesn't have one.
Sent from my Nexus 4 using Tapatalk 4
Asia above. 5w/40 fully synthetic which also meets 505.01, or 5w/30 fully synthetic which meets 507 spec. If its in fixed servicing then typically the 5w/40 505.01 is used. If on variable servicing or if it has a dpf, go for 507.
You can used the 507 even if its without dpf and on fixed servicing, but the 5w/40 505.01 will make the engine run quieter, as the oil is thicker. I run 5w/40 505.01 in my fabia 1.4 pd tdi..
