2005 Superb V6
Dear friends
I bought superb automatic v6
and on the engine written v6
and also V30
On the rear bonnet of the car the emblem shows only (Superb and under it V6) but they don't write 2.8
My previous car was the same skoda superb and it is written 2.8, this car is not written.
It is not diesel car.
So it must be 2.8 liter? or sometime 2.5 comes petrol.
Please let me know how to be sure it is 2.8
Petrol is 2.8 l engine and diesel is 2.5 l. It's still a V6 design though. 30V means it has 30 valves total.
Copy/paste from Wikipedia:
2.8 V6 30v 142kW[edit source | editbeta] identification parts code prefix: 078, ID codes: ACK, ALG, APR, AQD, AMX, AHA, ATQ engine displacement & engine configuration 2,771 cubic centimetres (169.1 cu in) V6 engine; bore x stroke: 82.5 by 86.4 millimetres (3.25 in × 3.40 in), stroke ratio: 0.95:1 - undersquare/long-stroke, 461.9 cc per cylinder, compression ratio: 10.6:1 cylinder block & crankcase cast steel; die-forged steel crankshaft cylinder heads & valvetrain cast aluminium alloy; five valves per cylinder, 30 valves total, hydraulic bucket tappets with automatic valve clearance compensation, 2x chain-driven double overhead camshaft (2xDOHC - twooverhead camshafts per cylinder bank - 'quad cam'), continuous adjusting variable valve timing for intake and exhaust camshafts (Inlet cams only) engine management Bosch Motronic electronic engine control unit (ECU); regular premium unleaded (98 octane normally or 95 with "lower power output", according to manual) DIN-rated motive power & torque output 142 kilowatts (193 PS; 190 bhp) @ 5,800 rpm; 280 newton metres (207 lbf·ft) @ 3,200 rpm applications Volkswagen Passat (1997–2005) including the Variant and Chinese Škoda Superb; Audi A4, Audi A6 and Audi A8
So it is 2.8 Liter  :sun:  :rock:
What else in the UAE?!  It's GOT to be a thirsty beast  :rock:
It is still normal, maybe soon...
