octavia 1.9tdi 105 bhp front shocker
does anyone know what front shocker mine will have on? My supplier said there is 3 different ones? its only the ambiente bxe estate model. many thanks. he said 50mm and two others?
Edited by johnyblade
Sorry its a 2007 mk2
I thought there were only two  50mm and 55mm.
My pov spec 56 plate L&K (105hp, tiny brakes) had the 50mm ones.  The hubs which came with the 312mm brakes were needless to say 55mm.
Just had a shocker fitter on my Ambiente Octy 56 reg and its the smaller one 50mm.
Sent from my iPhone 5 using Tapatalk.
Thats great thanks mine has the small Brakes too so should be the 50mm one hopefully
as above 50mm for a 1.9tdi as the hubs are dependent on the brake disc/caplier set up, other options may be for whether you have sports suspension fitted as an option
had it done it was the 50mm one. Mechanic said top bolts were very tight but all went well and feels much better to drive!!
