JabbaSport UK Polar Fis+ Distributors
Polar FIS+ Advanced, What is it ?
Advanced Polar FIS is the evolution of FIS + unit. It adds new parameters in addition to new features.
Polar FIS + enabled viewing vehicle parameters in the FIS screen, but Polar FIS Advanced, as well as incorporating more parameters, includes new features like the ability to modify the number of flashes of intermittent comfort indicators, function automatic lowering of the mirror on the passenger side when engaging reverse and some functions which are can only be activated with Diagnostic cable such as VCDS.
Parameters Available:
  • Real Speed extracted from ECU motor
  • External Temperature
  • RPM Engine
  • Battery Voltage
  • Petrol Tank Litres
  • Calculated Oil Temperature
  • Measured Oil Temperature
  • Engine Ambient Temperature
  • Intake Air Temperature
  • Cooler Temperature
  • Engine Coolant Output Temperature
  • Radiator Coolant Output Temperature
  • Fuel Temperature
  • Request Boost Presure
  • Measured Boost Pressure
  • Atmospheric Pressure
  • Intake Manifold Absolute Pressure
  • Required Fuel Pump Pressure
  • Measured Fuel Pump Pressure
  • Fuel Rail Pressure
  • Brake Pedal Pressure
  • Brake Pump Pressure
  • Calculated Engine Load
  • Measured Engine Load
  • Mass Air Flow
  • Mass Air Flow
  • Accelerator Pedal Position
  • Throttle Valve Position
  • Engine Torque
  • Engine Power (HP)
  • Oil Level
  • Oil Minimun Level
  • Injection Timing
  • Ignition Angle
  • Misfire Sum
  • Misfire Cylinder 1-12
  • Angle Delay Cylinder 1-12
  • Exhaust Temperature
  • Catalyst Input Temperature
  • AIR/FUEL Ratio (LAMBDA 1)
  • Fuel Trim Bank 1/3
  • Fuel Trim Bank 2/4
  • N75 Duty Cycle Specified
  • N75 Duty Cycle Actual
  • Injection Quantity
  • Injection Start
  • Injection Duration
  • Injection Start Quantity
  • Injection Quantity 1-12
  • EGR Duty Cycle, EGR 1
  • EGR Duty Cycle, EGR 2
  • Charge Pressure Control Specified
  • Charge Pressure Control Actual
  • Before Turbo Temperature
  • DPF Temperature, DPF 1
  • DPF Temperature, DPF 2
  • DPF Oil Ash Volume, DPF 1
  • DPF Oil Ash Volume, DPF 2
  • Percentage DPF Filling
  • DPF Regeneration Counter
  • DPF Input Temperature
  • DPF Output Temperature
  • G Lateral Force
These also allow fitment of the latest VW Bluetooth units, designed for white dot displays to vehicles fitted with red dot displays.
Firmware updatable, with constant updates with more and more features.
Complete plug and play, not messing around.
Demo videos - Official JabbaSport Video to folow:
£240 delivered anywhere in the UK.
