Lights Question Help
Is it possible to fit the same lights on my 1.4 tsi that are on  this 1.4 elegance(see pic)? front corner/bumper lights.I just have plastic trim where there could be lights.
Edited by dudgers
Yes, they will physically fit with no modifications required.
However the wiring won't be there to make the front fog lights or DRL's (Daytime Running Lights) work.
To get the DRL's to work properly they need to come on with the ignition and go off when you turn side or dipped headlights on. You therefore need to wire them up to the light switch on the dash and have the car coded to tell it DRL's are fitted. Alternatively you can use the wiring from an aftermarket kit instead.
The fog lights will need a new headlight switch, extra wiring and coding.
Edited by silver1011
Thank you
