Headlight Washers on FL Vrs
Can someone who has Headlight washers on their Vrs take some pictures of the hole in the bumper when the jet is up
Thats almost impossible. The jet only comes up once every 5 sprays of the washer jets. It sprays and goes straight back down
it is possible if you grab hold of it before it goes back down
It's also possible to pull them up manually. I needed to do that with my pre-FL when I swapped bumpers, in order to remove the colour-coded cap.
And you have long arms to be able to reach the wiper stalk from the front of the car :giggle:
Seriously, as above though all you need to do is gently pull them up manually.
What it is you need to see?
I want to see the hole that is cut in the bumper and the underside of the cap.
when I had my bumper off there was a marking for the headlight washer holes
bump?
Looks like I might have to cut a couple of holes now :giggle:
