Boost Gauges
Hi all
Excuse me if this is in the wrong section, im debating getting an octy vrs nearer xmas when my budget allows, so im just doing a bit of browsing around. Ive been reading a lot on these boost gauges, and it seems a lot of people have them mounted on the A pillar (think this is correct) but arent there any boost gauges that fit in the slot below the sterio? i did try a search but not much came up that was what i was looking for.
/edit - ones like this for instance:
how much and where would you get gauges like that from? or maybe some that are blue backlit? :)
i have a white boost guage that lights up blue mounted there
i used a blank plate and cut a hole in it. i'll see if i can find a pic
here you go, but i don't have a pic with it lit up
nice :) they look good. i think i'll have to get an octy for sure.
Personally, if it were down there, most of the time you would ignore it, or would not be looking were you are going while the needle is swinging to and fro.
My is pod mounted as close to the right hand of the steering wheel as poss so you can easily keep an eye on it. Afterall it is there so that you (potentially) have warning if the turbo is about to let go, not 'coz it looks good!?!
Lee
3 Gauge DIN Panel
DIN sized panel suitable for fitting 3 VDO gauges in your car in a stereo sized space.
Title Awesome Part # Price
3 Gauge DIN Panel IN-DT-NSPANEL-GO4
I'm getting
vdo_colpod also from awsomegti.
How many warning lights does that cover?
none, unless you drive a VW. As skoda don't use that panel.
Oo, in that case I like it a lot!
