The Factory Settings Button......
...on the Maxi Dot.  If you press it does it wipe out all the things that you have had coded through the VCDS?
i.e.:-  will it turn things off that you've had turned on?
Thanks Mike, I have a tendency to touch things I'm not supposed to touch, the wife included, sometimes    :think:
Worst case scenario is that anything that doesn't work after a factory reset will be restored by settingsin the maxidot. No VCDS work will be undone.
Mike
 As Mike said... I've reset it a couple of times & only the DST has been affected each time.
I've noticed in Maxi dot that there are Factory Reset's in most of the sub menu's, can you reset every one?
Thanks Mike, I have a tendency to touch things I'm not supposed to touch, the wife's included, sometimes :think:
Missing apostrophe added for you, Andy. HTH. ;)
