APR 1.8T Transverse K04 Kit for mk1 vrs
Not worth it hybrid ko3 will reduce more power for a lot less money !!
Think you meant to say "produce" more power Clive .lol.
Sent from my Samsung S3
Ooooopppppsss
Works out about £2.5k so dont come cheap
And its not the same turbo the states use to match the map
Usa use a k04-001 and iirc uk use to go with s turbodynamic hybrid or such
Uses oem injectors tho so trip computer mpg will stay true lol
Sooner buy a diff :)
Beach buggy hybrid all the way
SFS supersize TIP
Wellycooler
AEM water meth kit
Mapping to suit
Probably get all that for £1700-1800
Not sure on the spec of your car,so I'm not sure what else you would need!
Beach buggy hybrid all the way ...
Getting that from India might be a problem though
Those APR kits are suppose to basically be DIY, plug-and-play to any engine
Without any local(ish) custom mapping options it may be the only way to get beyond stage 1 power level
They still want mapping mate
Iirc and its still the same they use rs6 turbo internals, i looked into these to :)
Both will be better than you got but its alot of cash and i still think more benifit will be had from a diff and brake upgrade ( and suspension )
If ur stuck with nowhere to fit id sway to apr , backdraft motorsport use to list a k04-001
Unless being in india the states will ship it to you so you get the turbo the software was developed with ??
