Need some advice? :)
Hiya. Was just wondering the ways I could see if my car has been mapped by the previous owner?
Just that had a race with a couple friends and I managed to keep up with my friends 1.6VTI Civic Jordan that's 160bhp and can rev to 8500 rpm.
Its just a bit of a scare really because ive heard that if you have it running too high then it causes all kinds of problems like turbo failure etc.
Anyway I can find out without a rolling road? :(
Cheers.
Tom.
Also what do I need to do to my car to run a stage two map?
cheers!!
Cheers.
Tom.
Obviously this racing wasnt on a public highway of course, because that would be illegal ;)
Theres no sure fire way of physically looking at a car and saying "yeah thats remapped". Best way is to compare to someone with the same car that they know is standard. Or get it on a RR.
All this stage nonsense is just a way for companies to catagorise tuning steps. But they all do it differently to each other. Most would consider stage 2 as an exhaust, fmic, but on standard turbo i think?
Stage one just being a map and maybe an air filter if youre so inclined.
Hope this helps!
Luke
Sent using Tapatalk, like a bawsss!
That helps a lot. No-one around where I live that owns a VRS. And if they do, They're old and won't have a cheeky little play. And no was on a Dual carriageway :) so we weren't like hoooning! haha:)
Will bear that in mind. And by stage 2 I meant to be able to run about 200bhp? :)
Buy a £6 blue VCDS cable off ebay. download VCDS-lite,
Below is a direct quote from the awesome faboka vrs (member on here), when I asked the same question;
Log group 11. This shows requested and actual boost. Stock is 2350. So 3rd gear from 2k to redline.
Group 4 shows fueling duration and timing. Think it should be around 22.9degrees duration at 4k.
For stage 2, you'd probably need a hybrid turbo, FMIC and funds ready for an uprated clutch should that go.
Yeah but looking at the map myself I wouldn't have a clue what to look for ! :(
Or will it actually tell me the Power output?
Cheers :)
