Fabia reaction mudflaps
Bought a reaction a few weeks ago and I think I need some mud flaps fitted seen some supposedlyofficial skoda flaps online but is the reaction any different in spec to a basic model? As vrs and Monte Carlo flaps are not the same as a standard fabia.
Anyone have a part code for my reactions flaps front and rear??
Can't give you part numbers without ringing my dealer, but mine had mudflaps put on by the dealer as part of the deal (protection pack?).  I also added the door mouldings to break up the grey a bit.
I've never had mudflaps before as I fear they would come off when reversing up top a kerb or in snow, but the Reaction is sufficiently high for this to not be a problem (so far).
I actually think it doesn't look to bad with the OE ones on and they cover my slightly wider 215 tyres.  Tailgate still looks permanently dirty though, but I'm sure the mudflaps must help a bit.
I was concerned about drilling, but I think that existing holes are used.
Couldn't help but laugh when I saw a Reaction with a towbar!  Maybe it had the "extra cylinder" upgrade to compensate.
If yours is a hatch then the mudflaps code should be KEA 710 001 (rear) and KEA 700 001 (for the front).
Your trim level doesn't affect the body so the above should fit fine.
Ok thanks for the replies guys. Very helpful
Its only the Monte they don't fit as far as I know due to the extra plastic around the arches.
Same goes for the Scout because of those fender trims.
