ABS ring -04? Where?
it is part of the wheelbearing seal mate, either got damaged during the fitting of it or a cheap bearing that has no magnetis strips embedded in it.
Clean the sensor ring with a cotton bud dipped in methylated spirits.
DB
Ok, I will clean or fit a new bearing then.
Is it possible to fit it wrong way round? Ive seen the wheel bearing on other vehicles that need to be fitted a certain oriantation
If I remember it correctly it came with the "hub" or whatchamacallit (the part that the wheel bolts are threaded into) so it shouldn't be possible. This was a low priced bearing but it was specifically for vehicles with ABS
