High Beam assistant with bi-xenon
The brochure for the Octavia lists the following two options:
- Bi-Xenon, AFS and LED daytime running lights, cornering fog lights & light assistant (Includes rain sensor). £1190
- Intelligent light assistant with high beam control (Includes rain sensor). £440
What is the relationship between the two?
Does the first include all the functions of the second? Or if high beam control is desired with bi-xenon must both be ordered?
Intelligent light assistant is where the car automatically puts the headlights (highbeam) on under certain conditions (uses a camera behind the mirror) and over a certain speed.  When another car comes in the other direction it will turn them back to dipped.
option 1 above wont include ILA with high beam control as its a separate option so if you want the two it will be £1630.
(Light assistant is where it turns the lights on automatically when its dark)
ps, welcome to the forum :)
And how does 'AFS' relate to 'light assistant' and 'intelligent light assistant with high beam control'?
From the back of the brochure
AFS (Adaptive front light system)
AFS: Adaptive front light system is a
feature of Bi-Xenons and allows the
light beam to adapt to the car's
speed, direction and the weather
conditions. Urban driving emits a
shorter, wider beam whilst faster
driving emits a longer beam.
Cornering function sees the beam
turn up to 15 degrees in direction of
the steering wheel's turn. The beam
will also adjust according to car load,
acceleration and wet weather to
prevent dazzling oncoming vehicles.
http://www.youtube.com/watch?v=Beo1XF3t4f0
Light Assistant
Isnt really mentioned in the brochure but it basically uses sensors in the car to decide when its going dark and turns the lights on automatically (on dipped )> it also does the coming/leaving home lights where you go to the car in a dark carpark, unlock the doors and it puts the lights on so you can see.
From google
Light assistant
As a practical device, which simplifies the controlling of the car’s lighting, the Light assistant provides these functions:
Leaving home: Turns on the lights after unlocking the vehicle for easier finding of the convenient path to the car.
Coming home: If the light intensity outside is lower than a set level, this function provides pleasant illuminating of the path home.
Tunnel light: While driving, this function activates headlamps if the intensity of the outside lights abruptly decreases.
Day light: Turns the daytime running lights on after turning the ignition on.
Also integrated into the Light assistant system is the Rain lights function, which turns the lights on when the wipers are activated.
Finally the £440 option
Intelligent Light Assistant*. Using a camera mounted behind the rear view mirror, the
Intelligent Light Assistant* monitors light levels and determines what level of lighting is
required. The car then turns on the headlights or if required, the high beams. Should another
vehicle’s lights be spotted by the camera (either in front or moving in the opposite direction)
or the light levels improve sufficiently, the car will automatically turn down the high beams.
To activate this function the headlight switch must be sent to “auto” and the left stalk on the
steering column be moved forwards.
Capiche?
Fantastic, thanks for all the info, I now understand all lighting functions, and realise if I want high beam control with Bi-Xenons I need to order both of the above options.
I'm confused. I definitely have the rain sensing option and my lights come on in a tunnel, but as far as I can tell there is no camera behind the mirror. There are four sensors that look a bit like LEDs.
So which system have I got?
Thats normal Light Assist
you only get the camera with intelligent light assist
I have AFS on my R36, and I sometimes think there is a car approaching round a blind bend but it  is my headlights illuminating around the corner! They also come on when you are travelling over 80 mph (on a private track!  ;) )
