Skoda Octavia Water Leak Drivers side caused by Rear Washers
Hello all I am new to this forum and wondering if someone has the answer to this. I recently purchased a Skoda Octavia Classic Estate. Noticed that when I press the rear washer jet water leaks on the inside of the driver's side above the relay box. Took me a while to work it out. Only started looking at it as my horn kept sounding off and electrics playing up.
I am now trying to work out how this could happensand where the connections are that I need to look at to see where the water is coming from.
Has anyone had this happen to them before and where I should look to try and work out the routing of the pipes if they run through the interior.
Is this a simple fox or expensive i.e. does the dash need to come out
Does any one have any pics which would be useful as well
Any help would be appreciated
Hi many thanks - a little new to this so apologies
