Speedo Lights Problem
Part of my speedo light has decided to go off (see pic). Anyone else have/had this problem? Whilst driving they went off then back on a few times over a period of about 30 odd minutes, then stayed off :(
Looks like the LED's have gone :(
I'm guessing that you can't just pop in a second hand speedo.
why. Just replace the bulbs :)
At night just stick to residential areas and you will be fine ;)
Erm sounds like darkhero will be your best bet ;)
I doubt Charlie fancies a drive up there from Kent :giggle:
I dont know their locations :(
If I remember right I think dark hero has sone kind of guide ? I dont know though haha
Thanks for all the replies. I managed to find a couple of threads about the LEDS's for the dash, and it appears to be a case of carful soldering to replace the duff ones with new. Will have to give it some thought as to what route I want to take, if any, about getting a repair done.
Thanks again all :thumbup:
Yes careful soldering can replace them. Just 1 led failing cancause an area to fail. It could also be a dry solder joint. If you are going to resolved them just be careful to Mark which way the LEDs face
Thanks for that.
I can still see what speed I'm going for the moment, so it's not too bad for now. If the whole dial goes off, then I will have to get it sorted. I may send it some place like Cluster Repairs uk rather than chance it myself though.
