Urgent help needed, console bush stuck
Basically the cupra bush is stuck half way in my fitting tool nut and bolt have seized so i need someone with nuts bolts and probably and angle grinder to come help me out in cwmbran. If there is anyone who can they will be suitably beer tokened.
Hope there is someone to help,
Eddy
Thats why polibushes are easier . Just a firm press .
if your stuck can you use a hacksaw tp get off thread. Amd maybe a big hammer / vice to press it all the way in.
Btw dont know how tight they are bit plenty of oil around bushthen hold kkneeling between legs hold a block of wood over bush then hit it with a hammer . Hard!
Did you clean up the inside of the hole first with sandpaper ?
Btw note to critic's... I am giving the guy a "get me out of the ****" note. Yes its not the preferred way. But if it gets his car back on the road. Even temporary then its a win !
Hi, yeah i did consider poly bush but went cupra and it now looks like a mistake opps.
Think thats going to be my plan but its a high tensile bolt and my hacksaw seems to be having little to no effect.
And i have ti be honest i forgot!! so my own doing, sat staring at the sandpaper i bought to do it now!! :/
Thank you for the advice, il certainly try it :)
Cut the nut and split off ?
just been and got an angle grinder so its coming off now, then try remove the bush and start again
Sounds daft but make sure its lined up square. Or you will struggle.
Good luck. I just kicked my bushes on. On asda car park lay inder it booting thw wishbone. Got some odd looks haha
Managed to get it in and the car drivable so i can now get other side done professionally.
Cheers for your help
you done one side. You can do the other!
Dont gove up. Now you know whats coming so can prepare for it better
haha i have run out of patience and bolts to press it in too. CV gator wants doing too i have noticed to day so going to get it all sorted together.
Think i got lucky getting this side in and daren't push my luck too far and end up stuck again.
