Air filter
How do I change my air filter? I'm talking about motor filter not the one inside the car.
I saw that it is not so easy to open because of unreachable torx on the back.. does anyone have a guide with photos?
thanks
Or if it's a bit tight for ya undo clip on pipe from Engine To Airbox then undo big torx screw on right hand side of airbox (I think) at the bottom Which hold airbox to car then lift whole unit out will be stiff do to it being held by a rubber washer
Unscrew all torx, disconnect filter box from engine and slam panel, throw away.
Fit ITG Maxgoen using supplied Jubilee Clips.
And smile :)
1.6 TDI,
  get the correct filter, open Air filter box and replace old filter with the new one.
1.6 TDI,
+1 This may also work, especially has George has correctly identified which car you have :rofl:
Oops
