VCDS confusion
Hi I wonder if anyone can help.
I have been a very happy  VRS estate owner since october, (still very happy, best car i have ever had)  but the unlock thing with the doors is driving me nuts. I have borrowed a genuine vcds & cable  from a mate at work and thought i would make the following changes
SINGLE DOOR UNLOCK
46 – Cent Convenience
07 - Recode
The single door unlock give an even number i.e 00064.  To make all the doors unlock with one press, just add 1 i.e. 00065
ANTI HIJACK
46 – Central convenience
10 - Adaptation
Channel 03 Auto Lock (auto locks car after 10mph)
Channel 04 Auto Unlock (unlock the car when u take the key out)
STEERING ASSIST
44 – steering assist
07 - recode
Soft coding = 011x0  or 012x0
Replace x with a number from 1 – 9
2 = GTI
3 = Comfort
6 = Handicapped (very light)
When i look at the installed tab it doesn't have "46 central convenience" does this mean i cannot edit these changes.
Any help gratefully received and apologies if i'm being a numpty.
There's no 46 - Central convenience on mine either.  Most (if not all of them) are now in 9 - Cent. Elect. (J519). I've done the anti-hijack and it works and I've also changed the steering weight.  You did do an autoscan first?  And you are running the latest version of the software?
Edited by PhilTheGeek
many thanks,  found them !!
out of curiosity did you change the steering weight to xxx20 ?
Auto unlock doors when key removed)Cent Elect - 09Adaptation - 10Auto Lock/Unlock (set both to on)
Cent Elect - 09Coding - 07Long coding helperAutolock: Byte 0 - Bit 1Unlock: Byte 0 - Bit 2
Staging (needle sweep):
Instruments - 17 (5L0 920 480 K)
Adaptation - 10
Staging
On/Off
Sent from my GT-N7105 using Tapatalk
all done and tested.
love the heavier steering.
Many thanks all.
