Scratches
My 05 Black magic vrs seems to show every scratch whats the best way to remove them have 2 pretty nasty ones :(
Thanks for any help
Thanks for any help
It depends how deep they are, I suspect that you have only scratched the clearcoat. Can you feel the scratch if you drag your finger nail across the scratch?
If you can't then a dammed good rubbing with mettalic tcut or similar should do the trick. If you can then buy some clearcoat or better still a touch up stick with paint and clearcoat and apply with a cocktail stick a tiny bit at a time until it sits slightly proud of the surface. Leave for 2 weeks then get some tcut on a cotton bud and try and get it so that it is ever so slightly above surface level then use some good quality wax and polish like your life depends on it.
If you take your time you can do a repair that you will not notice.
Good luck with it :)
Thanks alot for the info no they seem more like scuffs than scratches will do as you sugested :)
I had a similar problem. What worked for me was a Meguiers clay bar and Scratch X. Then a few coats of turtle wax platinum wax. (Yes people recommend Meguiers wax but i read test reports and the TW beat it) :)
