Front door locked, now can't open door.
I have a Skoda Fabia VRS, the passenger side door lock appears to be broken and I'm unable to get the door open, I have a replacement lock but can't figure out how to get the door open to replace it.
Paul
An awkward job. I had to take a door card off on a rear and then beat the lock into submission with a hammer and a long screwdriver to get the door open to replace a lock. You'll give yourself more room to work if you can take the front seat out, assuming it's the front lock.
The rear is much more awkward, take out the seat base and work with the limited space to remove the door card and window carrier to get at the lock.
Good luck!
Tech1es guide may be of help
managed to getit open with a combination of pulling the latch up, trying to lock ulock the doors and bashing the door to try and shock some movement into it
