Bulb out warning
2 out of 3 times when starting the car and switching the lights on, I get a bulb out warning which then dissappears after a few minutes of driving. It's always the N/S tail light (top bulb) I have removed it and cleaned up the contacts, but this doesn't appear to have helped.
Is this a sign of the bulb on it's way out or a possible intermittent wiring problem?
IIRC it's a signal that the bulb could be about to fail.
Cheers, will get them replaced then.
Common for this are drl or numberplate lights
I think I read somewhere that it occurs as the filaments get older. Could be wrong though as usual :|
How do you mean? This is what the DRLs/numberplate lights do when they are on their way out?
I'll change them and let you know how they get on over the next day or two. :thumbup:
Yes. They give intermittent errors before finally giving up.
You were spot on. Had no warnings since changing the bulb.
