front seats and aircon flaps
Hi can I use front seats from a 2004 passat in my 2006 superb both are non electric?
Also found out today flaps for directing air to windscreen not operating fully anybody know a fix or
is it a major job.
mjjs2
If you mean the motor which controls the flap it is known as V85 - it is a bit of a pain but not dash out (as the factory service manual would have you believe) - assuming you are a little dextrous and delicate with things. I did a little write up of fixing it here:
 http://www.briskoda.net/forums/topic/292789-footwelldefroster-flap-positioning-motor-v85-where-is-it/
But you should check with VCDS to see if it is broken.  If your problem is actually that you have lots of condensation and it doesn't clear, it could be that your car is actually full of water...
Thanks for getting back I will check out both and let you know
Thanks again
mjjs2
If u take out pollen filter you can see a flap under it sometimes this flap gets stuck and heater stuck on recirculation mode causeing very bad condensation in car,, on my last car passat same as superb, u just lift bonnet, remove plastic piece were battery is, remove pollen filter under say left wiper, put yr hand in to flap and give it a gentle push in a bit and that will free flap..re,,,no condensation...pollen filter back in, battery cover back on etc etc...or yr pollen.filter seal could be gone, resulting in water getting into floor under carpet, search,, water ingress,, for a how to fix..
