mk 1 octy vrs surging issues after stage 2
hi guys am still getting surging problems after the stage 2 have recently changed to a brand new oem dv from my compbrake one and had a major service but problem persists from quarter of a pedal to 3 quarters have been told now possibly n75 valve but dont want to buy any more parts if i dont need them anybody had similar issues and finally found what the issue was all help is much appreciated
I had this issue on a standard car without a remap. I had to change the n75 valve and it cured the problem. May be worth seeing if a fellow member is local to you so you can swap parts to see if it is your n75 valve without you buying one first.
Do you have a boost gauge fitted ??
If so what's the boost looking like
yes have a boost gauge fitted and about 3 quartwers of a pedal it is dropping boost from about 1.4 psi to 1.2 mate
Psi or bar ??
Looks like you got the number wrong there.
yeah i did mate thought i put bar
Cool so when you dropping you mean as you feel the surge the boost drops as well??
I only ask as the boost should tail off at a given point.
You're currently holding around 20 psi which should then slowly tail off to somewhere around 12-14 maybe, does your s move slowly back or is it a noticeable drop which can be felt ?
no it does move slowly back its not noticeable but u no its doing it it feels like the car wants to be driven foot to the floor everywhere had none of these issues on stage 1 only since the stage 2
So it's not flicking back and forth then ??
How many miles on the car, I'm thinking that maybe the fuel pump can't keep up
no its not flicking back and forth u can just hear it rev for about 1k then hear it dump momentarily to atmosphere and does that every 1k-1.5k throughout the rev range but has no problems when u floor it
it does feel more noticeable the more pedal use but only does it intermittantly cant get it to do it all the time but at 3 quarters of a pedal it does have times when it feels like u notice the drop in the surge this has been bugging me ever since i had the stage 2
Who mapped it, might be worth going back to them to be honest.
Do you have access to VCDS ??
rtech mapped it  and no access to vcds have just got a cable but only have the lite version vag com but still have to install to lappy as my battery goosed and runs out of juice as soon as i get in car needs to be plugged in constantly :(
Edited by sav26
I think you can log Injector duty Cycle on the lite version, it's in the first few blocks for engine, have a look and let me know if you can,
I would think R-tech would be wiling to take a look for you, maybe a better option.
Another thought, when was the fuel filter last changed, it's not classed as a service item so may still be on the original.
had it done around 6 months ago the fuel filter and have asked rtech on a cpl of occasions who say i really need vcds on it first but that was before i changed dv and had the major service contacted them yesterday aswell to see if they had any ideas but am waiting to hear back
rtech have really good reviews about there maps what fuel reg have you got on
standard one as i was told by rtech when i went they have absolutely no use for the 4 bar reg i took with me and told me not to put it on as i still have it sat here
Call them, they may be able to help.
