To make standard dump valve louder ?
Hey I have a 09 TSI vrs and just put a NEUSPEED induction kit on today . It's not as loud dump valve noise as I was hoping so what can I do to make it louder . Heard about dump valve spacers etc or is it cheaper to get. After market DV ? Not wanting to spend much tho
Spacer is the cheaper option. I run a forge spacer with no issues and it's fairly loud ;)
How are you finding the induction kit? Any noticeable difference from standard ?
Sent from my iPhone 5
using Tapatalk
using Tapatalk
I will let u know after I have had a proper run in it. To early to tell.
Easy to fit tho took 10-15mins
How much are they ?
How much are they ?
Sometimes pop on eBay, I paid £30 for mine new & unused.
Retail is about £60
I just bought a Forge Spacer; running a Neuspeed P-Flo too. Can't wait to get it fitted.
Will look for a spacer I think. It's loud outside the car but quiet inside
Let me know how it sounds when fitted
I'll try and get a video when fitted; should be next weekend.
I got an email back from aesomeGTI where they adviced me on the induction kit. They say that as I'm standard it won't be that loud as it's standard boost. They say a spacer won't make it really any louder and only way to make it louder is to run a stage 1 map as it increases the boost so more air being released
Mine is a stage 1. Boost increases from 8 psi to 14 psi. It sounds louder through my intake- the spacer will simply help amplify the noise.
Load of rubbish. Mines standard with just an intake and spacer and it's as loud as any other dv sound I've heard.
Nice one so do u think it's worth it ?
If it's that noise your after then definitely, I'll try and get a sound clip when our lass is in from work
Magic cheers . Does it sound loud inside the car as well ?
Yep :)
I love the way companies do that just spend £350 + on a re-map it will make it louder, only when on full throttle/full boost but not much louder, theres a forge spacer on ebay now £40 i think .
Not very good quality as it's windy but you get the jist ;)
Got my spacer today. No instructions etc . By forges website I need to jack up the car to go underneath ? Is there no way to reach it from above . Any fitting guide in here
Jack up the car, Take drivers wheel off, remove arch liner (easier access) and you'll see the dv. Undo plug from dv, undo 3 Allen bolts and remove dv. Fit dv into spacer and attach back to the car using the longer bolts, fit plug bk into dv, re fit liner and wheel. Jobs a good un
Magic cheers
My BDM Intake (ITG copy)
