Instrument help
hi does anyone know of how to remove the plastic screen protecting the speedo, and other gauges. cheers.
Remove the dash cluster and it seperates.
you know them aluminium rings u can fir to the speedo etc. i was wanting to do that. how on earth do i take offthe instrument cluster
cheers in advance damien
There's a ~20cm wide plastic peace just beneath the instrument cluster (and above the steering wheel). Pull it out and you will find 2 torx screws (don't know the size, though). Unscrew them and pull the cluster out. Be careful not to brake the plastic screen ;) (as I managed to do so). Now just unclip the front part (with the screen). There's no need to disconnect the wires to put those alu-rings.
Cheers!
