Change from coilovers to standard
I'm going to change from coilovers to standard suspension as the wife has started to drive, apart from the springs and dampers what else should I change at the same time, thanks
..what else should I change at the same time
i suspect someone is going to mention "the wife"?
not me of course..
It was a tough decision between the wife and coilovers
Does the wife look better now than when you first met her? If she's like mine, then probably not.
Does the car look better with the coilovers? Almost certainly.
Pretty simple choice when it's put like that.... :rofl:
Haha fair one, but it's either go back to standard or get my gearbox ripped out on a speed bump
Have you not considered just raising the coilovers to a near standard ride height? Afterall their adjustable for a reason.
I asked a mate about it and he said it would make the ride really unstable and bouncy? But I'm not too sure if it would
The lower you go the bouncier it gets, if you raise them it'll be a better quality ride just a little stiffer
