Washer bottle empty warning light
Hi All, yesterday my warning light for the washer bottle level on my Lauren and Klement Occy started to come on. I have now filled it to top but warning light still flashes on - not all the time but several times during a short journey. Any ideas please.
Ron
Dunno I'm afraid.
But - does anyone know, please: what is the capacity of the washer bottle?  I've driven my Octavia for thousands of miles and used the washer regularly - still haven't needed to top-up yet!
I put in 3 liters so itis at least that.
capacity is 3 litres but if you have headlight washers it is 5.5  litres .
5.5 litres?  Wow, that's gallons!
A lot better than a Mazda MX-5 - the washer bottle there is about half a fluid ounce!  And the silly thing is, on the Mk3 MX-5 there would be room for a bottle almost twice as big.  Dur.
Edited by Stuarted
That is why Octavias with headlamp washers sit much lower on the off side :giggle:
With capacities like these why would anyone need a warning light anyway?
Good practice suggests regularly checking such levels so I can't imaging the bottle running dry between checks... unless off-roading is the main use (or laziness is the norm  :giggle: ).
eccleshill is right about the extra wieght oh the offside but makes it easier to negotiate round-a-bouts at speed  :rock:
But makes entering and leaving the roundabout a bit dodgy - in countries where you drive on the left (most of the time).
I used a complete full bottle on a run from Whitby to Preston and back during the winter . Surprising how mucky the M62 is during the winter months!
Mike
I bet you didn't need a warning light to tell you it was empty though. :think:  The fact that you knew you were using washers so much probably told you it was running low...
my washer bottle holds 5 litres and my car doesn't have headlight washers
